Overflow tank advice
LGOMEZ90
Mar 26, 2012
Modesto, California
Looked through some of the fancy work you guys have done making overflow tanks but noticed one major issue. Where does the sensor go? Do i cut a hole on the bottom as well? My oem resevoir had a hole on bottom for the sensor to plug it. Do i even need the sensor?
I think most folks are doing away with it, but you can easily cut a hole and re-use an OEM sensor in about whatever container you have.
I believe some years didn't have the sensor either. I know my 95 did, but my 99 didn't.
edit - i should add the sensor is only for the idiot light in the dash so not using one isn't going to impact general operation of the car.
Its not a nesessity. There is a guy on here in the freelancer section that sells awesome overflow vans for 1G's and 2G's.
