leaking overflow tank
Well to start with the cap on the thermo its probably a bad seal. Blowing it out the overflow tank is probably because theres pressure build up somewhere. does the car get hot when this happens?
I would say replace the cap asap. Worst case scenario although I seriously doubt it, unless you are boosting 20+psi, the head is lifting and pressurizing the coolant lines.
i got a new cap. i didnt put it on yet. waiting for it to cool down 1st. im not running 20+ psi LOL. im running stock psi whatever stock is. and my motor is rebuilt so i dont think the head is lifting
but the car does not overheat at all. its just when i park the overflow leaks a small amount of coolent nothing huge.
