Only upgrading one cam
dsmsucks
660
4
May 14, 2005
Rochester, New York
I wanted to know if anybody has tried it? I heard the intake cam is good but the exhaust sucks. What would be the outcome of using a stock intake/264 exhaust?
thanks
Im not going to do it, just wondering:)
Well the cam control how far and long the valve is open. By upgrading one cam and not the other your setting your car up to run like crap. See if you put a bigger intake cam you will putting more air in so you will want a cam to get the air out.
for some weird reason I want some Chicken....
But hes right that wouldnt be the smartest thing to do. why let more air in and not be able to get all that air out?
Sorry i didnt understand what you were talking about at first. Well if you find one that would mate well with the stock one it would work. But i still think it would work better doing both.
It might work, alot of people run the 264/272 combo with no problems. But I'm not sure what the grind of a stock cam is.
Seems to me half you guys didnt read the thread. He said that he wanted to upgrade the exhaust cam. You can also get a single cam on dsmtrader.
I cant see that causing any trouble. If anything, the car would run better. However, I'd just go ahead and do both. The idea would be similar to to only replacing half of your sparkplugs. Not very bright.
