fp2 intake cam only
bcjjones
509
6
Nov 3, 2011
Austin, Texas
Would I be able to run a comp cam 101200 (fp2 ) intake cam with the stock exhaust cam? Would there be any problems/adverse affects to doing this?
Or would running the stock cams be best until I get my fp2 exhaust csm fixed?
Basically I'm trying to figure out if ill benefit from running the fp2 intake cam with the stock exhaust?
depends on what stock cam you have.
Yes the car will run on a stock exhaust and a FP intake
Its a stock turbo exhaust cam from a 1991 galant vr4...will I benefit from running the fp2 intake vs the stock intake?
Thank you. So running the fp2 intake with the stock exhaust cam I have wouldn't benefit me at all?
Sorry, I was thinking B cam, not A cam, It has about 360 lift and a 244* duration, the A cams have more lift than most of the stock cams.
The G exhaust, if you can find it would be a decent fit
