One Fan only!!
mitsu29
207
Mar 11, 2005
Northridge, California
Ok one of my fans isnt working and i want to know whats wrong.
The radiator fan is triggered by a temperature sensor attached to the radiator. Have you checked the fuse?
I tried changing the temp sensor and checked the fuse and still its not turning on. the ac side turns on ive tried running the car with the ac on to see if both fans turn on and only the ac driver side turns on? what do i do!?!?!
Could be a bad fan relay. Try unplugging the fan and supplying it with 12V (to check if the fan is ok). If it does, jumper/replace the fan relay.
FYI.. a nice VFAQ HERE on running both fans simultaneously for better cooling (also shows a diagram of the OEM wiring) :dsm:
I used that VFAQ to wire both fans together and it worked wonderfully. It was very simple to do and gives that extra bit of protection. I suggest it if you've only got one fan running or want some extra cooling.
