One Fan Only
Status
Not open for further replies.
mitsu29
207
Mar 11, 2005
Northridge, California
Ok i have friend whos radiator fan that is not working. his AC fan(drivers side) works but the other one doesnt. I tried turning on the ac but only the ac fan turns on. Ive changed the temp sensor and checked the fuse but it still doesnt turn on!! help us out!!
If the fan wont turn on and the fuse is good, then the motor in the fan is probably burnt out. Try tapping on it with a hammer while it should be running. If that doesn't work try swapping in a friends fan that does work and see if it works on your car or vice a versa hook your fan up on a friends car and see if it works. If it doesn't work replace if it does then you know you have a short somewhere
ddavisaf said:
1 post wasn't good enough, you had to make two?
listen here mr. uber thread elitist. sorry for the double post as when i hit the button to start that thread i got an error message, and then my internet browser closed on me, so i figured it didnt post my thread. i figured wrong, OMFG!!!! the world is at an end!!!!someone posted a a double post jesus its over hurry run for cover!! jeez man lighten up ITS just a thread! relax its gonna be ok mr. Troll!
Honestly to all the others i am very sorry i did do a double post, but hey stuff happens! :sneaky:
Pardon?
Don't get an attitude because you were told not to do something. No need to get huffy about it. Just be careful not to double post.
If it happens again ask a moderator to remove or move your other thread. Please don't post it twice.
Status
