Only runs with cam sensor unplugged
96Gs-T-Eclipse
Nov 30, 2010
Thornton, Colorado
Ok so here's my delima my 99 eclipse turbo conversion only runs with the cam position sensor unplugged if I plug it in it kills the spark only. I have checked the timing over and over and the timing is dead on ive replaced cam sensor and target magnet I've checked for wave forms and getting waveform signal just running out of testing ideas please help if you have ran into this before. I have stage 2 turbo grind cams from crower. Running stock crank shaft
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
