2G Oil return line..
Inkdlyfe
438
8
Feb 23, 2016
Summer feild, Florida
What would be best for the oil line from the turbo to the oil pan ? I need a new one the guy before me ran it across the exhaust and created a hole need to replace it where and what should I use I got another oil pan now
I run -12AN drain on my Holset and others run -10AN, but I have just cut the "flex" part out of a stock line and replaced it with reinforced rubber line and clamped it to both ends of the drain tube if you need a quick fix.
