Oil relief port and pressure
cjridert1
403
6
Jul 4, 2007
Akron, Ohio
Which hole the the oil relief?? I couldnt make out which one. I attached an image with my best guess, let me know if I am right.
Also, how are most people measuring the oil pressure @ the feedline? I have dsmlink, but Im sure this ECU value is only @ the filter housing, rather than center housing (or do you guys treat them as the same?)
Thanks
That is the correct hole. AS for how far to grind it, i don't know, but from what i've read you don't want to get too close to the piston sealing surface.
