Oil Pump Shaft
Tanro
2,457
96
Jul 22, 2009
Montgomery, Alabama
So the 6 bolt I have was put together with no oil pump in it at all. I have been rebuilding it because it was cranked and spun all the bearings.
I was wondering what the P/N is for the shaft that goes from the oil pump through the block. I am doing a balance shaft elimination is that part of the balance shaft system? Sorry if these questions are stupid but I have been reading a bit on the forums and I am a bit confused right now because I ordered a new pump but not revcieve this shaft.
Make sure you rotate the BS bearings so the oil hole in the block is pluged or else you wont have oil pressure when you start it.
