Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
I started cleaning and inspecting various parts for my new engine build tonight, and want to get some advice on the front cover.
The cover and oil pump gears look to be in good shape. There is no play or wear on the gears, but the end of the stub shaft is chewed up where you put a wrench on the back side to hold the oil pump sprocket. There is some very slight "grooving" for lack of a better word on the stub shaft as well...but it is very slight; you can barely see or feel it. The cover has the BS removal freeze plug in it, and the two seals, pump sprocket, and castle nut were replaced with new OEM ones about 5-6k miles ago.
I'll try to get some pics posted, but in the mean time:
1. Can I buy just the stub shaft somewhere?
EDIT: Answered this one myself; found the Mirage shaft with the oil groove
2. Do you think the front cover is still good? The seals still look look and feel new, with no visible wear (I'll replace them though anyway if I keep this cover). If anything, I may want to replace the back gear cover (is it available separately?), but I don't think the slight wear from the stub shaft is even worth that.
3. There is no lateral play that I can detect in the gears, and VERY slight thrust wear visible on the cover. There is a slight bit of in/out play, but I think that is normal? Does anyone have the go/no-go numbers handy for the oil pump?
I really don't want to sink $300 into a new cover/oil pump, but obviously I don't want to take any unnecessary risks with my new motor either.
Are the topline kits from Extreme PSI any good? (Also, they don't show any gears in the pic).
Thanks guys...
Craig
Thanks guys...
Craig
). It's my opinion, but if lateral play were a concern, the service manual would have put in limits. I'd run it.
