oil pump question
rarest_90_DsM
285
3
Jul 21, 2004
akron, Ohio
I let my car sit for 2 years now ive been working on it and im at the point where i have started it but it pushes no oil pressure. we tried cranking it over for 30 seconds to build oil pressure nothing oil filter is dry. then we poured in fresh oil started it let it run for a minute nothing. the only changes we have made is switched to a 90 ofh and ran a external cooler. is it possible that it would need primed just from sitting? or could it just go bad for no reason. shouldn't it self prime? the front case was never removed and is the stock unit. any insight is welcome.
primed the pump runs like a champ must have just unprimed itself after sitting for so long. so does anyone know if these oil pumps should be self priming?
