OIL pump/cooler electrical
kidmet
Supporting Member
217
21
Jul 23, 2012
Aurora, Colorado
This could be my last question before priming the engine! I have three wires hanging by the oil pump/cooler. Solid yellow, yellow with a small red stripe, and blue with white stripe. I know where two wires are to be attached... Don't know which ones and what about the third?
The middle one with the yellow plug goes to your power steering pump, forgot what the dummy oil light is , i use a aftermarket oil pressure, i think its blue. And the yellow is the low oil indicator.
Thanks to everyone. I've run out of energy to start the thing. If it starts, I have a lot of mounting/clean up. But, I will be proud of myself for picking up someone's swap project and finishing it. It's all hooked up, just need to prime it.
Pics of the wires will help a lot, take some pics of the end wires and where they come off the harness.
You said your aftermarket gauge doesn't work, where is this hooked up to?, what brand gauge you have, take some pics of the gauge and the lines where it hooks up to.
Pressure gauge works and car runs! I just gotta put it back together to get her driving. Pretty excited. Aftermarket gauge works now too and I've got pressure!
