Oil cooler
I'd search a little more. You don't just throw on an oil cooler. You need a new OFH or a sandwhich adapter. And a Balance shaft eliminator kit, does just that, eliminates the balance shaft. And since you want an oil cooler and need a new OFH ill let you search for the OFH port mod.
The balance shaft eliminator eliminates the balance shafts. It is not necessary, however I recommend it, as it's kind of a preventative maintenance type deal. That is one less belt to break and if it does break, it can and most likely will take out the timing belt, and you have yourself an expensive repair bill.
The oil cooler on ebay, I know quite a few people who run them with no issues. And you'll need a new oil filter housing.
I personally got the EVO 3 OFH and Oil Cooler Kit from Extreme psi just don't get the push on fittings get the true earl fitting due to the push fittings coming loose and no one wants oil sprayed all over the road and engine goes boom.
^ There is no reason why the push lock fittings should come off, unless the fitting/hose is the wrong size. Once they go on, they should NOT be pulled off easily.
