oil cooler
BLINKY619
1,211
4
Feb 26, 2010
SAN DIEGO, California
ok i made my 6bolt swap and needed to put an oil cooler... so i decided to reroute the two lines that came out of the oil filter housing and add a complete new oil cooler kit... so i just wanted some input if i was on the right track...! thanks
anybody????
that should work however you may have trouble with damage from flying debris i would try to find a vented steel plate to cover it, possibly add 2 small fans if you have the room.
Probably not becuase I had almost 1/2 inch between my 3'' dp and oil filter.
On a side note, ditch the fram filter. Please.
I dont think so, those are just as durable as an ac condenser which, is right behind it.
