oil pressure sending unit relocation
Up by the power steering pump resevoir is where mine is at.
I had the same issue before, the metal solid engine mounts killed 3 sending units and finally I used -4 A/N fittings and a short -4 A/N line between the oil filter housing and the sending unit and hold the sending unit with zip-tie somewhere does not have much vibration then the issue was solved. Now I used an AEM oil pressure sensor on the oil filter housing and totally no issue for a couple of years.
