Oil Sending Unit Relocation Kit?
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
I think my auto meter oil sending unit took a dump on me yesterday and now Im wondering if the relocation kit worth buying from exterme psi? How accurate is the reading with it being relocated?
It's just a 14" line that relocates it... The pressure will still be the same within the line, so your readings should be no different than they normally would be.;)
I just threw together my own kit: an fittings, npt adaptor, sender, 2 ft of line. Relocated sender next to the ps pump. Works great and accurate! Make sure to use thread sealer on connections.
How common is this problem, and how long do these sending unit normally last in the factory spot?
I have never personally heard of this happening from vibration. I have run them on stock and built motors in the factory location and currently run one in the stock location with no issues so far.:pray:
