Oil pressure gauge installation
dsm_Prince
119
Apr 7, 2008
Lawrence, Massachusetts
I baught two glow shift gauges boost and oil pressure, im having a difficult time installing the oil pressure gauge. How does the stock pressure sender look like and where is it located? Anyone with pics would help ill try to post up some pics later when it stops raining.
the stock oil unit is right by the oil filter. depending on the thread size you should be able to unscrew the stock seding unit and screw in the sending unit from the gauge.
not to revive old threads but i have the same gauges and i know where everything goes but my only question is if the aftermarket sender is the same tread size as the stock one?...
i wana put a "t" so i can run both senders any sugestions?
