420A Oil pan return line tap help
DrewmHolland
171
36
Apr 11, 2022
franklin, Tennessee
I just ordered a Chinese turbo off of eBay and before I tap my oil pan for the return line I would really like some tips and to know what size fittings y’all 420a turbo guys are using
Makes sense to me I’m probably gonna tap it up high over the deep part of the pan so it can go straight back to the pickup tube, I’ve also heard that I need something to pinch off some oil flow to the turbo so I don’t blow the seals but idk what to look for
I can't speak too deep into this matter but there are oil restrictors that can be ran in line with the oil feed line to reduce flow of oil to the turbo. I believe the restrictor is dependent upon the turbo you have and what its oil requirements are but may be a place to start if I'm not speaking on something you have already looked into.
I know with 4g63 oil pans they have the return dump for the turbo oil offset from where the pick up tube is at (deep part of the pan) so that may also be a good spot to locate the oil return for your set up if it's feasible. If they did it for the 4g63 it's probably a good way to go for the 420a plus this will put you at a very high point and well away from where the oil collects (just in support of what was already stated above)
If a turbo drain line is at the level of the oil or below it, it will pool in the return line and cause problems, as they have to drain all of the oil that is being fed so that the CHRA doesn't get slowed down by the backup of oil.
