420A ss braided oil return line
selmerguy
1,810
23
Nov 14, 2004
Killeen, Texas
just bought the 20" one....damn late night internet shopping sprees ROFL
I find that when I make my own SS braided lines, It too much hassle, especially for a measly oil drain line that rely's on gravity to drain back into the pan. Now sure, w/ a fuel supply or return line, its worth it to make the SS braided line, but not the drain. Sure it looks good and if it works flawlessly for $20 then great news, especially if its pre-made.
But do you know how easy it is for me to simply replace my drain line every time I pull my turbo? Its so hard to fit a big ol wrench down there that I just cut my drain line in half and then cut the rest off and simply push on a new peice of 5/8 hydraulic or Earls -10 pushlock line, whichever I have laying around. I have the -10 fittings, and this for me is cheap, and easy every time.
my drain line gets hot from my dp so i have to go with the braided line.
selmerguy said:
if you want to get the fittings the 10 an is 5/8 tube. from my turbo drain flange it is 1/2 npt to 5/8 tube. good luck
what fittings?
never melted but it got soft.
as for the fittings. you will need tube/an fittings from the turbo and on the oil pan. for me my drain side of the turbo is 1/2 npt. and i welded a 3/8 bung on the oil pan. so i needed to convert those to 5/8 male tube fittings. get it??? good :thumb:
LOL ROFL
I already have fittings....on my return line, I'm already turbo remember ;)
I'm just getting an ss line as compared to the gates hose i'm running now :thumb:
XMasta19 said:
LOL ROFL
oh.... i had 5/8 heater hose going to hose barbs attached with hose clamps. didn't know you were better off than me. good luck with the hose.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
