FPR Return line
wrknmike924
92
Sep 4, 2008
Cary, North Carolina
Running the portfueler on my now turbo 420a. Had to run a return line from the FPR to the rear of the car. Currently have the line as around a 5/16th's i think. But my fuel pressure at idle sits at 30psi and is still running rich. If i crank the psi to 50ish where it should sit the car bogs badly and cuts off.
Wondering what size return line people are running from there FPR?
When the car hits anywhere in boost she smooths out and runs strong and pulls strong.
Please help! Thanks.
The stock size (on a '95 with a full return) is about 1/4", so your problem probably lays elsewhere.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
