oil pan baffle
TAL0NTSi
161
Dec 26, 2010
Westerville, Ohio
Hey guys,
I recently finished my build and ran into a small issue. The oil pan baffle off of my old motor does not line up correctly with the new motor. I sort of rigged it up but it's causing an oil pan leak.
My question is, does anyone know how I can figure out the part number for a 1997 oil pan baffle. I called Mitsubishi and they said they're all the same, which O know isn't true.
Thanks in advance
Yeah, I'm sure. It only bolts up one way due to the hole for the dipstick. I believe that my new block is from a 96-99 7 bolt, which has a different baffle than the 94-95's
I had the same problem with my baffle not lining up properly, i ended up drilling holes in the baffle and sourcing new bolts to mount it to the girdle. Haven't ran the motor yet but i couldn't see it affecting the motor at all.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
