Oil on Head and exhaust manifold
1qwikspyder
Feb 17, 2005
San Antonio, Texas
I have recently rebuilt my motor, block and head. Head has crower springs retainers, and si 1mm oversized valves, new stem seals, etc... Anyways, since I've had it back, I've been noticing oil on the head right above the exhaust manifold and what looks to be soaked into the manifold. When I took the manifold off, there was wet oil all over the nuts and washers that hold the manifold on. It is doing this to all the runners on the manifold. However, when I took the manifold off I could not find any wet oil in the runners on the manifold or head. What could be causing this? O BTW, car doesn't smoke out the exhaust but seems to smoke in the engine bay (not bad, but at night I can see smoke in front of the headlights). Thanks in advanced.
There is an oil journal behind one of the studs. I believe it is the lower middle stud. The stud actually blocks the hole that goes right into the journal. So if you have no stud, you will have a massive oil leak. If you could post pocs that would be great. And I would say the reason it smokes under the hood is because of the burning oil on the scortching hot manifold.
Steven
Check the valve cover bolts, make sure they are still torqued to spec. Sometimes after a new gasket is put on it can put pressure on whatever is on top of it, pushing it up just barely, allowing oil to seap out.
The last time that I saw that it was because the valve cover was cracked and oil was seeping thru the weep hole onto the exhaust manifold. Check to see if there is any oil on top of the valve cover under the spark plug wire cover. If there is, then there ya go.
Let us know what you find.
Also, there is an oil gally plug located right where the oil feed line bolts up. If that is loose or has been removed recently it might need to be resealed. RTV works fine. You can just coat the threads and screw it back in.
    • Sdcryan1
