oil leaks
lil corb
758
7
Sep 7, 2005
Woodbridge, Virginia
well, I just sent got word from chrysler dealer than the transfer case is not leaking it's just massive oil leaks. Turns out the oil return line, oil feed line, oil pressure sensor, front and rear main seals, balancer shaft seals, oil pan gasket seal, oil coolant lines, and slave cylinder and slave lines are all leaking :notgood: Question is I know all the stuff besides, front and main seals are fairly easy but what about the slave cylinder? It's on the back of the block right?
thanks
Whoa, thats alot of leaks.
All of those are fairly easy to replace besides the rear main. Even the front main and balance shaft seals are not to bad to get to. The slave cylinder is located right on the front bottom of the transmission. Very easy to replace, just 2 bolts holding it to the transmission and 1 bolt cennecting the fluid line to the slave itself.
