oil leak
The first thing to check and the simplest, would be the center bottom exhaust manifold stud.
Yes, that stud is an open hole into an oil return to the block.
It is a fairly common spot to leak.
You might want to check the turbo drain tube that connects to the oil pan, it is a notorious leak also, at least in my experience with a few DSM's. I think every one of them I have fooled around with was leaking their. The oil filter housing is another spot that I have problems with. There is also an excentric pulley that leaks from the bolt hole that it attaches to, but it is inside the motors front cover, down low. Just MTC, hope it helps.
