oil leak
Did you just change your oil filter? Possible someone didnt get the other gasket from the old filter? If not you need to chase the leak further up the block. Hard to tell from your pic sorry.
Looks like the stud for the oil cooler has backed out. This is real common. Pull the filter and see if the stud is loose. If so than it will need to be re torqued. Loctite will help keep it tight. It is possible that you have some internal damage to the engine now also.
Also I had the huge bolt that the oil filter screws come out on me. I think it was a 23mm deep well to tighten it up.
Thats what bryan is talking about.
OP the oil filter screws onto the oil cooler housing. The piece the filter actually screws onto can loosen as it is a stud that screws into the housing. DO NOT overtighten this stud. The entire housing is an oil cooler and if you overtighten it you will crush it and mix oil and coolant.
im going to have to check it out after work which is 13 hrs from now, i really hope i dont have any internal damage done to the engine because i just bought this car two months ago.
it appears that stud has backed out, i cant seem to find any loctite laying around in the garage of course when i need it its nowhere to be found LOL. thank you guys for all the help i really do appreciate it
