Oil leak will not go away
krummel45
231
Apr 23, 2003
Tampa, Florida
My oil return hose will not stop leaking has any one else had this problem also what should I do to fix it?
wheres it EXACTLY leaking from... the flex section, where it meets the pan, or where it bolts onto the turbo?????
At the pan flange? Put copper crush washers under the capscrew heads. Tighten GENTLY.
Crack in the pipe? Take it off, saw out the flex section and replace it with some silicone tubing from an industrial supply shop.
