will not go in gear!
dale187
292
Jun 28, 2008
Dover, Delaware
About a month ago i started having problems with my clutch master. I just kept putting fluid in it until i was ble to change it out. Well it started getting worse and worse the leak that is. A couple times i let it get too low to where i had to re bleed the clutch. Now, mind you when i bled it it wouldnt shoot out it would just pee out, Thats how bad it was. Well yesterday i was n the way home from work and i realized the car was harder to get into gear. Then i was at a light and then it wouldnt go in at all. So we put the new master in and rebled it and the clutch feels amazing better than ever, but now it wont go into gear.
Any ideas? The fork is moving in and out and the slave cylinder was moving in and out.
You double checked the fluid level, and made sure nothing was leaking?
Does the pedal need to be adjusted? Does it grind trying to go in or it hits a "wall"?
