Oil Leak near timing belt tensioner
Talyn
443
19
Jun 10, 2012
Pittsburgh, Pennsylvania
Basically my car was leaking oil badly, getting on the timing belt which was slinging it everywhere, I took the motor apart(was also burning some oil). To check things out, and replace the belt(timing belt+oil=bad) and fix the leak(I hope).
Well the tensioner itself has oil on it, and there is oil all over the top of the timing cover(The inner metal one for timing belt b(aka balance shaft).
I am not sure if the tensioner is leaking or if something else in or near the inner timing cover is, I'm looking for input on the most likely culprit or a list of all the possibilities in that general area. But at least now I have a more specific area to look in.
Already replaced the cam seals(have not run the engine since however, still putting it back together) And I will be pulling the cover, just want to know what to look 3or, I would hate to put this all back together and still have this oil leak, I forgot to ask, but does the tensioner use a spring or oil pressure?
I had an EVO 9 that was doing just what you are talking about. It had a timing job done before I bought it and it turned out that they didnt tighten the 2 bolts that hold the tensioner on and it was coming through the bottom hole and leaking into the front cover. Hope this helps!
It was leaking through the tensioner bolts? The two on the tensioner arm?
Front balance shaft seal or crank seal. There's nowhere else in the area of the tensioner than oil could come from unless it's coming from behind the tensioner itself.
I have a pretty bad leak myself. Trying to diagnose it. If you have a sec check out my thread here: http://www.dsmtuners.com/forums/newbie-forum/468570-help-find-oil-leak-lots-pics.html#post153315669
Thanks
PS: Sorry about the thread jack
The tensioner bolt runs right between the two large oil galleries on the front of the block. Oil can find its way up thru that bolt. Seal both bolts when you put it back together.
These 2?
