Oil Leak Help?
Check the valve cover gasket, and vent tube coming from the valve cover.
Same thing ended up happening to a friend of mine and it ended up being the vcg like mentioned above. Hope it is because it's an easy fix :thumb:
Along with the valve cover gasket, common leaky components include the half moon, the turbo oil feed line, and the CAS due to a bad o-ring.
i hope its the vc jeeesuss :p i drove it for a little bit expecting to do a build and the oil cap flew off, what that pressure cause it to do that if it was the vc? nooby question i know LOL.
