Oil leak help
assad112000
May 8, 2011
tacoma, Washington
Alright so just got my dsm a week ago and learning more and more everyday but just wanted to know exactly where a very small oil leak is coming from. Usually its a coupe of drops here and there so nothing to bad. Couple drops leak after car is turned off. I thought it was coming from the oil pan but it doesn seem so from the pic i took. Anyways here is a quick pic...
THANKS!
You really need to look around above where you see the leak to determine where it is coming from. Having said that, if your DSM is only leaking a few drops I wouldn't be too concerned. Just keep an eye on the oil level between changes and make sure it is not loosing too much oil.
