1G Oil filter line, where does it go?
Colossus
890
4
Jun 23, 2003
Crestview, Florida
Ok. You have the oil filter housing. On the bottom of that housing is a small rod which connects via a rubber house to a green bent metal tubing. This tubing goes up the exhaust (front) side of the block, behind the turbo, around to the side and then ends right by the main water line. Now, where this pipe ends, I have no connection. I have nothing leading anywhere. Where in the hell does this oil line go or end up connecting to?
Also, which order on the distributor does the spark plug wires go in? The Haynes manual gives 2 different orders.
It's a coolant line for the water-cooler oil cooler. It connects to a barb fitting on the thermostat housing, I would assume and of the fittings pointing toward the radiator would work, but one above the thermostat would let the oil warm up faster in the winter time.
The wires should go 4-1-2-3 standing on the driver's side going from left (radiator) to right (firewall). Also, 1-4-2-3, 4-1-3-2, & 1-4-3-2 will work as well.
Jay
  • For sale NEW Magnus Forged Transfercase gears
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
