disconnected vacuum line, where does it go?
BuNcHeSs
May 5, 2013
Sheboygan, Wisconsin
I was swapping the stock intake pipe to a hard pipe and I noticed that the other end of the vacuum line that is right after the MAF (right next to the recirculating line for the BOV) was not connected to anything. Ive searched multiple vacuum diagrams and couldnt find anything to help me. Anyone know where it goes?
If it is the about 1/2" diameter one, then that line goes back to the EGR system. You can either hook it back up to your new intake pipe or cap the hole on the intake pipe and remove your EGR.
The EGR is under the battery tray right?
Yes, most of it is under the battery. Charcoal canister location varies, for some its on the gas tank filler neck, others under the battery, and some on the front drivers side under the frame rail area I believe.
Isn't that the EVAP Canister in those locations. Thought the EGR is under the intake manifold?
The EGR is on the intake manifold, right under the throttle body.
Sorry I got carried away and started lumping the EGR and EVAP systems together. As stated the EGR valve is under the throttle body on the side of the intake manifold.
The way I wrote it made it sound like I thought the charcoal canister was the EGR valve, I assumed he would want to delete EVAP with EGR and embellished without explaining what I was talking about. Sorry for the confusion.
