Oil feed off head what thread is the whole?
DsMWookie
360
May 3, 2004
Birmingham, Alabama
I am about to run and make a SS line but I need to know the thread pitch for the whole so I can pick out the right fitting. Being that I can't drag my motor their makes it a little difficult. I thought it was a pipe thread so I figured I can't just run a bolt in to find out the size.
That is incorrect. There are no 1/8NPT threads from the factory on a Mitsubishi. There is a bunch of 1/8BSP (JPT) but I believe he asked for the one that feeds the turbo which is 10x1.25mm.
If it's the one on the OFH the one he was asking about, it is 3/8BSP and a 3/8NPT will only catch a few threads but it seems to do the job. I prefer to run a tap in there first if the housing is off the engine.
I found out it was a 10. 1.25mm the feed line for the turbo is what I was refering too. I blocked it off with a bolt and crush washer from a non turbo since they don't use that oil feed.
A 10mm x 1.25 fitting will not fit in the oil feed hole on my head. I have a JDM head, would that make a difference? I can get a 1/8" NPT to start a couple threads but the 10mm will not even start, it's too big.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
