oil feed from cylinder head
left front corner (assuming front is the exh. manifold side). If you need a stock hard feed line for it msg me. I have one for a 14b/16g turbo. Brand new.
thanks actually i just found it just now...
thanks for the offer but i'm getting a SS line to put in..
another question... what do i plug my stock oil line that goes to the oil filter with when i put in a line to the head ? anyone know what size nut i need?
if u have an oil line coming from the filter it should be a stainless line correct? if thats the case then leave it, its giving your turbo the cleanest oil it can get. i have mine run from the oil filter housing. maybe im just misunderstanding you....
cool, no prob, if your going to do a stainless line (i did also thats why i dont need the feed line) you should use the oil tap from the stock filter location. As your turbo will only get filtered oil from that location. Then you dont have to plug anything either.
i meant braided ss, i need to move it to the cylinder head because i'm going to be running a fp3052, bb turbos need less oil pressure then non bb turbos--so i've read...
