Oil feed from the head, different sizes?
kennyg
46
Mar 14, 2007
Winnipeg, MB, Canada
Just curious if there was ever different threads used on the head for the oil feed line?
I have an auto now that I just picked up and the hole/threads are bigger Than on my two other cylinder heads I have in the garage.
Or is it what I'm thinking and the guy had it drilled and retapped a bigger size? Cause this is new to me and the factory oil feed line I just ordered won't work:ohdamn:
On the auto and manual 6/7 bolt mine have all been the same size. Sounds modified to me as well.
Thanks for the quick response guys, I didn't think I ordered the wrong part.
Think I'm just gonna block it off and source from the ofh, not in the mood to swap to one of the other heads I have
One last quick question,
The guy before had made his own feed line and he had cross threaded it into the head, when I plug it what should I use so it doesn't leak? Rtv sealent or put a bead of in weld around it maybe?
