oil burning question
sarge
261
Nov 4, 2003
my car has 120k miles on it, and its been burning oil since 95k miles
the car started smoking a lot more when i took of the 17c turbo and put on my 50 trim. it smokes quite a bit more after you drive it hard, and some days it might not burn much oil at all.
my question is, what is causing this? bad valve stem seals? cracked rings?
the vacuum at idle is anywhere from 16-17, or even close to 20, so i was thinking if my problem was real bad( aka cracked rings), the idle vac would be shitty
anyone got ideas?
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
