Oil blow out valve cover
twobad312
Mar 26, 2009
Aurora, Illinois
Im having a problem with oil blowing out cam position sensor, the breather valve and out the cap. Car has a new cap, new gaskets on valve cover. Would oil pump cause these problems?
Replace your PVC valve with a OEM one and see if that helps.
I see the same issue to where I have some oil blow by in the the valve cover valley near my rubber boots of the spark plugs. It seems to be coming from the valve cover bolts.
Will re sealing the valve cover and new gasket help this? Looks like the Bolts set into a sleeved bushing. Could those be old increasing blow by?
    • george bromwell
    • pma1123
    • Sdcryan1
