air blowing out of valve cover.
obx tsi
199
Dec 1, 2005
Manteo, North Carolina
Is this normal? Never noticed this before, but when the car is running if you remove the oil cap you can feel air blowing out from there. Thanks.
Well, the engine is pressureized and it creates vaccum. There should be a bit of oil flying out as well if you took the oil cap off.
Yes it did have oil coming out. I quess with all of the boost leaks maybe it just was not as noticable before. Thanks, I am just so paranoid with this car after my flywheel blew apart on the last one.
I never noticed this either, because I never had air coming out of my crankcase vent tube. But then i fount a crack in my VC, swapped them, and BAM air out the breather!
jesus, i've seen a crank fall apart before.
atlguyinbama said:
... either from a bad PCV, or blowbye. Change the PCV, and do a compression test.
After checking the PCV for proper functionality, like atlguyinbama said, do a compression test. Unless something is seriously wrong the compression test should come up just about normal. One thing that would help you out thought would be a leak down test. This test would pin point the leak within the engine allowing you to distinguish where is it coming from ... In this particular case I would assume that the leak is your valve seals allowing some compression from the cylinder to come up through the head and into the valve cover.
http://www.dsmgrrrl.com/FAQs/compression.htm
I do want to make it clear that there will always be a little air/pressure within the valve cover. To check this simply take the oil fill cap off and place your hand over the hole with the engine running. If you can feel the pressure building underneath your hand, then you have blow-by (this is assuming that you replaced or have a working PCV and no obstructions in those lines). Again, this blow-by can be verified by performing a leak down test; take the link below to learn how to do this.
http://www.dsmgrrrl.com/FAQs/leakdown.htm
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
