Offset of Rim???
kareem17
92
Oct 14, 2003
Sarnia,
18"x8.5" With 32 Offset
will these rims cause any problems with my suspension? or what type of offset should I be using???
what size tire are you using?
That offset is defintely on the low side if you're gonna use 225's. I have 45 offset on 225/40/18 which fits perfect. Read wret's article in the tech article section. As long as you stay above a 30 offset you should be okay but stock is 46 so getting a little closer to that isn't a bad idea if possible. 8.5 is a little on the wide side also but it still should fit..
well I haven't purchased them yet, because of the offset issue. and about the tire size, they do not come with tires, so my next question would have been what tire size should I go with? I really do not plan on lowering the car if I don't have to, so I want it to look clean, and not have a huge gap if possible. what do you think?
You will have a large gap unless you want to get larger then stock diameter tires. Thats a bad idea though. Easier to get a set of lowering springs then dealing with issues like possible rubbing, reduced acceleration, higher price, and inaccurate speedometer/odometer.
225/40/18 is the common and "safe" bet.
you can also go 235/40/18 pretty easily though have to be careful about lowering, offset, and fender rolling.The 235 just means its just 5mm wider on each side then the 225.
I'm using 235/40/18 on a 18/8 with 41mm and its Very close but no rubbing. The allignment is with in spec and the car is lowered 1.5inches..I would stick with 8inch wide..
At that width and offset you won't get your wheels to tuck under your fenders. Unless you keep your ride height on the high side and get stiffer springs, it'll rub like a cat in heat.
I would try to stay near +40mm offset. It gives you more options and you won't have any inner rubbing with 235's.
