Oem steering wheel vs Grant?
ByrdClaw
144
Aug 21, 2007
Sacramento, California
I have a grant steering wheel that came with the car,and its like 13". I have an OEM wheel also,should I switch back to the OEM? is there any benefit in running grant over OEM or vica versa?
Since the 1g wheels don't have an airbag anyway, you don't have that to worry about. I'm not sure of the diameter of the factory wheel, but ultimately it comes down to personal preference then. A wider wheel will give you more leverage, making it easier to turn. Other then that weight and what the material is that you actually grip, are the only other factors I can think of to consider.
And you also don't get the steering wheel hitting your leg with the stock ones (big prob with 2gs)
    • george bromwell
    • pma1123
    • Sdcryan1
