Oem seats from other cars
has anyone seen or heard of any of the recaro volkswagen seats in a 2g? curious to see if those would fit
My s2k was recently t-boned..
If the insurance company, writes my car off, I will probably buy it back and take the seats out to throw in my 2G!
Stand by for update!
:thumb:
Has anyone successfully completely a Tiburon seat swap in a 2g? I have a chance to get some for cheap but I want to get an idea of how they look in our cars first.
However be warned that the seat might sit too high. I had this issue in another car where I swapped seats.
This. Even same model car, for some reason. When I had my Rx7, I got seats from a couple of years newer (but the same body style), and my head was near the ceiling. It was acceptable, but I didn't like it. It was something I hadn't considered before buying.
I'm completely performance minded, so I would get lighter, lower seats to lower the center of gravity. But not too low or you will always feel you have to sit up straight to get a clear view.
I personally feel that I need proper head supports for the G-Forces, so I'll be getting aftermarket racing seats. If you can't stay in front of the steering wheel, you can't effectively steer the ship.
Car: 1992 Plymouth Laser :laser:
Seat: 2006 Evo Mr Recaro
Seat in my room
Seat in my Laser :laser:
:hellyeah::hellyeah::laser::laser:
Epic sexiness is epic! :thumb:
anyone know where to find deals on evo 9 mt seats? I had rsx seats in my gs
Those are RSX seats?WTF
Seat in my room
Wow!! IS the same for a 2g? I want them!!!
MR2 seats are awesome too!
Found pics of the celica seats in a 2g. Not too bad, but i would go with something a little different.
...Found a set of these in my junker, so im going to be giving them a try!
I have 99' black leather in my car now, and i dont want to mess them up-ill never find another set if something happens.
Although ive seen Paul's car in person, I still dont know if I will like it as much as a set of aftermarket bucket seats...if not in the DSM, ill put em in my All Trac ^_^
NO, they are N/A 3G seats....I wanna know HOW the fronts were installed. I tried to swap 2g brackets onto them but they are riveted into the seatback. i cannot see an easy way to mod them.
the REARS fit 100% drop in tho :)
Figured id let u guys know that with a little fabrication these seats look and fit great in my car, I used the factory tabs on the bottom of my stock seat (front&back) i Removed the tabs off the SRT seats with a little measurment tool called a tape measure & some trusty 1/4in flat stock. looks great cumfy and way better than the stock GSX seats pics soon!!!!:hellyeah::thumb:
Pics of the seats in the car as well as of your bracketry. The problem with flat bar is that in an accident it does not provide much strength. But I would like to see what you came up with before I judge.
Ill setup some pics ### after all the triangle welded into this flat stock for strength its probally stronger than the factory setup, and the best part of it all is u cant see it and the factory finish trim sits perfect over the bolts in the floor
