Paching's Eclipse GST
Mitsubishi Eclipse GST
K&N air filter,
Apex Neo afc,
Aluminum intake pipe,
Aluminum upper/lower intercooler pipes,
Alumnum radiator,
Aluminum adjustable cam gears,
HKS sequential blow-off valve to ambient,
Dual guage pod,
AEM Uego Air/Fuel, Boost gauge,
3 in. stainless SRS cat-back exhaust,
3 in. stainless steel downpipe,
stainless steel header,
stainless oxygen sensor pipe,
Greddy counter weighted shifter,
ebay short shifter,
16g turbo set at 16psi,
manual boost controller,
Greddy turbo timer,
battery grounding kit,
Front mounted intercooler,
Aluminum catch can,
Fidanza aluminum flywheel,
9mm spark plug wires,
NGK BPR7ES plugs,
Excedy clutch kit,
brass shifter cable bushings,
polyurethane shifter mount bushings,
polyurethane motor and tranny mounts,
new 2gb front bumper,
new 2gb r
Mods-Engine
Rebuilt 6-bolt block
Balance shaft eliminated
Resurfaced head
Cometic metal head gasket
Multiangle valve job
Mods-EMS & Logging
Apex Neo afc
Mods-Drivetrain
Polyurethane motor and tranny mounts
coilover suspention and four cross drilled rotors,
18 in. Volt rims,
Parts Wishlist
ECM link,
650 injectors,
Forged bottom end
272/264 HKS cams
double spring valve kit
titanium retainers
ARP studs
electronic boost controler
ball bearing turbo
38 mm wastegate
Aftermarket intake
Donor gsx for all wheel conversion
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Nitrous : No
Fuel Used : Pump gas
Tires : Street Radials
Sponsored Car : no
0.0 lb/ft
Dyno Type
Mustang Dyno
Dyno Shop Name
Central Florida Turbo, Orlando, Florida
Dyno Session Details
Nitrous : No Nitrous
Turbo : 16G
Boost : 16
Paching
More in 2G DSM
Share this Vehicle
