OEM Part Numbers/Cross Reference
inxs
May 1, 2009
Champaign, Illinois
I am trying to help a friend find parts for a 97 Eclipse GST FWD MT. His timing belt broke and the pistons hit the valves. He bought a used working head and just has to have it milled and swap out the cams from his car.
I was hoping to go to a nearby You-Pull-It place to find some of the other miscellaneous parts.
Here is where I need some help. His crank angle sensor under the timing belt cover was destroyed. Also the timing belt covers are messed up. I wanted to know if there was a way to find out what cars used the same sensor, timing belt cover, etc... so I have a better chance of finding donor cars at this place.
Thanks for the help.
The crank angle sensor is the same (which is what the OP inquired about), the cam sensor is not. If it were the cam sensor, he would need a 97-99 unit, not a 95-96 unit.
Thanks for the information and quick replies. The cam sensor is bolted on to the cylinder head, and the original one is ok. The one bolted by the crankshaft is toast.
The 95-99 eclipse is the second generation, so I will look for those vehicles. What other vehicles came with that engine?
This will be a stupid question, but I am not so familiar with DSM vehicles. How can I tell a 6-bolt swap from the original engine?
