OEM or 4 layer?
240kid
153
Dec 19, 2004
downingtown, Pennsylvania
How good is the stock manifold to head gasket? Do you really need the 4 layer?
I assume you're talking about exhaust manifold. 4 layer will help to seal if your manifold is warped, which it most likely is. You can always get your manifold surfaced, and then you don't need to worry about a 4 layer to help make sure it seals. It cost me $25 to get my manifold surfaced. It's up to you if you which way you want to go to make sure it seals. 4 layer is cheaper versus surfacing, but not much. Seems like more of a band-aid, but if it seals, who cares?
hmm, my manifold could very well be warped. For some reason ( i think a timing issue) my manifold glows orange more often than not, so after all those cycles of heating and cooling......Is the OEM mani gasket a 2 layer gasket?
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
