2G OEM Turbo Rebuild Kits?
Ecotecdriver
Sep 29, 2021
El Paso, Texas
1995 gst. So my current oem turbo began to fail. Is it worth to rebuild it and where can I find a good kit or what is a good turbo replacement. I´m not looking foward to get more power, what could be a good replacement for the oem turbo? Thanks
Typically by the time you notice a TB2566 is failing, it's already junk being they're so undersized...not to mention we're reaching a period in time where if the turbo has higher mileage, the turbine housings are cracked externally. Unless you're intentionally trying to stay stock for whatever reason, this is usually seen as an opportunity to upgrade.
