O2 sensor problems
Chris cavallo
Nov 15, 2016
Clark, New Jersey
Just installed ecmlink v3 and front o2 was not cycling. Staying constant at .80 volts at idle cruising and wot. So i replaced the o2 being that it was probably original with a brand new bosch and im still getting the same readings. Stft is 5% until i pass 4k rpm and the ltft low is -12.5. Afr at idle locked in open loop is 13.5 and if i unlock and let it go into closed loop the stft goes even further and the afr at idle shoots right to 20. No matter what i do the car doesnt react. I know this has been asked so many times already and im new to the dsm community so any help is much appreciated, i just want to get the car running correctly, thank you.
