Fuel problems or o2 sensor
darkiller_666
477
Feb 19, 2008
Salina, Kansas
my girlfriend bought me a narrowband air/fuel ratio gauge. she doesnt know the difference between wideband or narrowband, but it was free and im sure she would have been upset if i just let it sit in garage. So i hooked it up, it almost allways reads lean, sometimes moving slightly to the stoich after light throttle or shifting gears. I dont know if this is caused by a bad o2 sensor or if my engine just isnt getting proper fuel. Boost is set to a minimum and regardles of correction on the Safc the Air/fuel allways stay low lean during idle and throughout most driving conditions. didnt know if i should think fuel pump injectors or something fuel delivery related or a bad sensor. Shoot me sum knowledge.
well obviously having it showed me that the signal my ecu was receiving for my fuel trims is blatantly wrong. is that useless. i understand its not as accurate as a wideband. but its more accurate then guessing by the sounds of the car...
A narrowband will indicate up to a certain degree of accuracy the a/f ratio. It is however not to be used for proper tuning.
I would check the output of the O2 sensor with a multimeter to rule out a bum gauge.
Also, what wire do you have tapped for the gauge?
number 76 on the ecu the top wire of the two white ones in the middle of the top plug towards the side of the firewall. i hope that makes sense. like i said the gauge does fluctuate some. but almost always lean. I am also getting horrible gas mileage, about 10-14 a gallon. I am not trying to tune with the narrowband i dont even run with my boost higher then stock. The car is currently a DD and i need to make sure it lasts until i have my build funded entirely and a second car so it can be down for some months.
The ranges should be as follow on that wire:
LEAN RANGE: (.050 to .249V)
STOICHIOMETRIC RANGE: (.250 to .749V)
RICH RANGE: (.750 to 1.000V)
See if it changes as you put the accelerator down, if it does the gauge is bum :( if it doesn't, change the sensor.
Hope this helps.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
