Nylon boost hose coming out (Autometer)
AdoreGSX
368
Aug 18, 2004
Wilmington, North Carolina
The nylon hose that goes into the boost guage, is not held by anything, is there something in particular i need to do to fix this or rig it? Its getting pretty damn annoying. :confused:
I didnt clarify...it just slippes out of the back of the guage, if your not holding it tight yourself, then you can hear it leaking.
yes, but the ferrulle doesnt do anything really, just slides over the tubing
That hose fitting is called a compression fitting and it uses a small brass piece that looks like a bead which slips over the hose. When you tighten the fitting, this bead is crushed and grips/seals the hose.
You can find them at hardware and auto parts stores or from places like MSC or McMaster-Carr http://www1.mscdirect.com/CGI/NNSRIT?PARTPG=NNLMK32&PMPXNO=1904877
