NWHTanK's Eclipse GST (AWD swap)
GST (AWD swap)
If I were to tell you that as long as you find the CAN IDs for those systems, make sure your custom IDs dont collide you can easily make them work? I am sure you already know that though, but for anyone else reading this that is possible.
For Pi5 I plan to use a similar setup but with the studio version of the DAC8x for a sound controller. However, due to possible noise from the power supply of the car hat it will use a relocated power supply (M4-ATX) that will also power the Riverdi displays and Teesny 4.1 (not the BCM Teensy).
I like what youre doing here as it is giving motivation to create mine amd find where I need to make changes to my plans.
Given what your design use is with the ESPs it makes sense to have a dedicated graphics control. The Teensy isnt designed for that but wont necessarily be used for that either. One is a BCM while the other sends data to the displays which have their own dedicated MCUs.
We have similar ideas with different approaches to similar solutions.
Some of us do exist but it is neat knowing I am not alone in building the unique.
That 18x22 looks pretty sound (pun intended), looks to be a simpler route than preventing noise to an open circuit board... might have to look into that one.
